Advanced Distant Light doesn't show up
Rock3DRock3D Posts: 5
I installed advanced distant light into Daz Studio Pro 4.6, the name shows up in the Content Library product list, however nothing shows up in the library to select.
I can't seem to figure out how to get it to work.
  • TotteTotte Posts: 15,283
    Its under Light Presents / Age Of Armor in the Content Library Pane
  • Rock3DRock3D Posts: 5
    not showing up there... the only thing I have in the light presents are the defaults for studio, nothing listed for Age of Armor
    How did you install it (using DIM or manually) and if via DIM, did you intall it to the correct location?
    edited March 2014
    I installed it using DIM, everything else I've ever installed works well. However, this is the first time I've installed a preset. DIM installed it wherever it's default are. Do I need to path it to a specific location?
    Post edited by Rock3D on
    Did you install Advanced Distant Lights or the Distant Lights Preset?The Presets require that you have the lights AFAIK.
    I was the lights, just checked to make sure I didn't buy the wrong thing.
    Are you looking in the content Library or the smart content pane?
    This is where I find mine.
    1014 x 441 - 73K
    Great, thats where is was.
