ZBrush problem (Old pose displayed)
Hello!
A few days ago I started to use ZBrush.
While I was working on a DAZ scene, I used ZBrush for the first time on a Genisis 8 Female to display "pressure" on her face.
Everything worked.
An hour later I was working with the same G8 character and did send it to ZBrush again (Different pose).
But the G8 Female still displays the pose and morphs from the first time I did send her there.
What can I do to reset this? Why isn't the pose changing to the new one?
It's like there is now a universal setting for "Genisis 8 Female.".
I did go to "Preferences --> Init ZBrush" and reseted everything. Still.
(The character has a hidden Goldenpalace shell. This shell does display the new pose but the "G8" doesn't.)
I can't seem to find a solution. :(
Thank you in advance!
  • Richard HaseltineRichard Haseltine Posts: 111,441
    Have you tried closing ZBrush?
  • duckbombduckbomb Posts: 585
    GoZ saves a file with transfer information and stuff, so you can try clearing that.  Under preferences, and the GoZ, there's a button to clear cache files.  DAZ will lock these files, though, if it's open, so closing out completely (and verifying in task manager) needs to be done first.  Failing that, do this:
    1) restart computer
    2) open ZBrush and clear GoZ cache
    3) open DIM and uninstall GoZ
    4) restart computer
    5) open DIM and reinstall GoZ
    it should work.  The reason for restarting is to completely verify the system wipes out those old files and that your installing into a clean slate.
    It may seem drastic, but it's my go to step when I frak up GoZ...
