bug with daz camera when animating with space pilot?
angusshmangusangusshmangus Posts: 0
Hi
I'm using my space pilot to animate the camera by hitting the play button in the timeline and then flying the camera around. It works for the most part great as it records keyframes in realtime. However whenever I play back the animation about 95% of it is ok but every so often the camera goes crazy and spins in all directions before returning back to its proper behavior. any idea why this is happening?
cheers
Angus
  • Richard HaseltineRichard Haseltine Posts: 111,992
    edited March 2014
    There could be problems in the past if the camera (or an item) animated through the 180 degree rotation mark - would that be about where you see the issues?
  • angusshmangusangusshmangus Posts: 0
    Hi
    It seems to happen even when the camera is travelling along a reasonably straight path. It seems to be quite random. The camera goes bezerk over a few frames and completely flips and then returns back to normal for a while until the next glitch...
    What are its rotation settings either side of the wild spell?
