Clothing from Blender to DAZ
Hi,
I've modelled a hoddie that I want to export from Blender to DAZ, but I've no idea how and I can't get it to work. Are there any tutorials or guides on how to accomplish this?
Thanks in advance!
  • Richard HaseltineRichard Haseltine Posts: 111,786
    Export as OBJ, import into DS (making sure it lines up with the zeroed base figure as imported), Edit>Figure>Transfer Utility setting the Source as the base figure and the trget as the OBJ should get you started. You coudl also try using dForce - Edit>Figure>Geometry>Add dForce Modifier: Dynamic Surface - and run a simulation from the zero pose.
