Niggly issue with Ultracenery Landscape System
Doc AcmeDoc Acme Posts: 1,153
This isn't particularly a Tech Support worthy level of problem I don't believe, but it does need to be corrected from "Higher Up".
Upon first launch it complains that it can find:
... runtime/textures/howiefarkes/ultrascenery/terrain/usc_autumnleaves_01_2048_diffuse.png
Where as there IS a:
...Runtime\Textures\HowieFarkes\UltraScenery\Terrain\USC_Autumnleaves_01_1024_diffuse.png", which is what I used to satisfy in the meantime.
So Im gonna go out on a limb (pun intended) here & guess that a 1K leaf map got substituted for a 2K somewhere along the line.
I'm sure a 1K map for a leaf is perfectly fine, but might that missing image be available some where or should a request go out to the PA or DAZ to correct the metadata of the product?
    edited March 2020
    Missing texture images and/or wrong calls for texture images are indeed a matter for CS ticket.
    Post edited by Catherine3678ab on
  • NorthOf45NorthOf45 Posts: 5,915
    Someone already mentioned that in the Commercial thread. HowieFarkes is aware...
  • Doc AcmeDoc Acme Posts: 1,153
    OK, thanks.  Just seemed since that the product has been out for awhile, that would have been noticed long ago.
  • HowieFarkesHowieFarkes Posts: 635
    Am uploading the fix for this right now - can't say how long it will take to get through Daz QA process though.
    Yes indeed at one stage there was a 2k texture map for that ecology but frankly it was overkill. It's 99% covered in instanced trees, leaves and grass and was just taking up precious GPU RAM for no discernable gain. My bad that it got uploaded while there was still a link to it but that is being sorted now.
  • Thank you :-)
    Thank ya sir.
    Ya, I waz wondering about that for a leaf.  I'll check if the DIM in the morning then.
    Perhaps I can get a clarification HowieFarkes for the correct use of the USC Camera view. Since it isn't a camera itself, is it simply parented to an exisitng?
  • barbultbarbult Posts: 27,628
    Lots of good info in the commercial thread. https://www.daz3d.com/forums/discussion/comment/5432236/#Comment_5432236
    Perhaps, but something pretty basic that should be in the docs.  Not really in the mood to wade through a dozen pages...
    You can ignore it - it is used by the script as a helper.
    Thank ya sir.
    Technically it wasn't for a leaf it was the ground texture of fallen leaves.
    edited March 2020
    Thank ya sir.
    Ah.  OK.  Don't think I've seen the update show up in DIM yet, but when I loaded the script this eve, it didn't request that file.  Used a much sparcer scene so most likely just didn't call for that.
    Rendered out the first test earlier.  Looks gorgeous. 15min @ 2K so pretty decent.
    Pretty amazing script over all.
    1920 x 1080 - 5M
    Post edited by Doc Acme on
