Patches of Hair Disappear After a Few Seconds
HeavensDisciples
If I add hair to a model, it appears just fine for a few seconds; then patches of hair disappear from the model just after those few seconds.
Does anyone know what could be causing this? I'm using Marcus for Genesis 8 and Shaved Side Dread hair.
EDIT:
I saved, closed, and reopened the file and he same thing happened again. The hair appeared fine for 10 to 20 seconds only.
SOLUTION:
I've found a work around for this issue for anyone that encounters this problem:
- In the [Scenes] tab, highlight [Marcus].
- In the [Parameters] tab, go to [Marcus > General > Mesh Resolution] and under [SubDivision Algorithm], change the drop menu value from [Catmark] to [Loop].
1246 x 571 - 714K
Post edited by HeavensDisciples on
