Install Manager cannot find required path! HOW TO SET UP?
dddonedddone Posts: 0
I'm using Windows 7 64 bit.
I purchased Light Dome Pro-R from Dream Light,
When I tried to install Light Dome Pro-R(Photo Shop) from
inside Install Manager it failed.
here is the error message->
Install Manager cannot find a required path. The installer for "Light Dome PRO - R (Photoshop)" requires that the installed path for "Photoshop CS6, CS5, CS4, CS3, CS2" be defined. Make sure that a path for this application is present on the "Applications" page of the "Settings" dialog, then try again.
Question,Step by step how do I set up a path to fix this issue?
I have the same issue with trying to install Photoshop 3D Bridge for Daz 4.5+(Windows 64 bit)
Thanks
Daz newbie
  • fixmypcmikefixmypcmike Posts: 19,738
    Click the Settings (gear) icon in the upper right corner, then click on the Applications tab. Click the + sign in the lower left to add Photoshop, specifying the version, bit depth, and path to the application.
