FBX - Studded Jeans Outfit
What is an FBX file and can it be used in DAZ alone? Do I need another software to make it work. Thanks for the help!
Post edited by clubmakai_c27ed75ea0 on
  • felisfelis Posts: 6,575
    FBX is a file format for a 3D model, and yes Daz Studio can import FBX files.
    But in order to make them wotk they need to be modelled to that character base, e.g. G8M.
    After import you will then need to do a transfer rigging to the model you wan't to use them on. Some uses might look a little off without changing the weight paint, but if you can use them with dForce you don't need to worry about that.
