Iray Rendering
KeithHKeithH Posts: 338
edited March 2020 in The Commons
Hi -
Does it make a difference if I let my scene render Iray in the preview pane before hitting the Iray button?
Thanks - Keith
Post edited by KeithH on
  • fastbike1fastbike1 Posts: 4,085
    Not really.
  • Matt_CastleMatt_Castle Posts: 3,312
    It can. The VRAM doesn't seem to flush fully after each Iray render (only on completely restarting DS), so it's possible that previously having rendered in the viewport may end up forcing the scene to render on CPU rather than GPU.
    In any case, it's not advisable to do both at the same time (probably not what you were suggesting, but just being sure).
  • KeithHKeithH Posts: 338
    Thank you -
    Another difference between both is the preview screen uses Iray Interactive, which is a scaled down version (less features = more speed)
    You can also put the render engine on Interactive if you want more speed but less features.
  • TaozTaoz Posts: 10,401
    The opposite is often the case though - doing a small and quick render (a few seconds is enough) in a separate window and keeping it open in the background will often (depending on the scene, I believe it works best with smaller scenes) make the preview respond faster to scene changes.  Subsequent renders in a separate window will usually also start rendering faster.
