How do I downgrade dazstudio?
The latest version of Dazstudio uses optixprime even though it is disabled. This causes my GPU to run out of memory on scenes that I had plenty of memory with previous daz studio versions. Where can find the download for the previous dazstudio? Or how can I completely disable Optixprime(or whatever "feature" is causing the problem)?
The only way to get it is to put in a support ticket and request a previous version. I have not tried it and have not seen any confirmation that anyone has actually recieved a previous version.
Open a support ticket. They'll put you through a bunch of (mostly useless) troubleshooting steps (reinstall DS, upgrade/downgrade to specific drivers, reinstall manually if you used DIM or with DIM if you installed manually, do a clean install, try the current Beta, update your OS, etc.) and ask for logs, but eventually they'll send you a previous version. (Took almost 2 weeks and dozens of emails in my case, but they did eventually capitulate and send me 4.10 (though in the meantime, I'd figured out a workaround for 4.11 that I could live with).)
Thanks everyone, I will try support.
