What's wrong with my "Plug-In"?
Leo ChenLeo Chen Posts: 697
And which products they are belong to?
1315 x 952 - 288K
1219 x 866 - 172K
930 x 724 - 156K
  • TotteTotte Posts: 15,289
    Animated Textures Plug In for DAZ Studio: This plugin is compatible with Daz Studio 3.x only.
    And I guess you have installed a DS 3 version of figure setup tools too.
  • Leo ChenLeo Chen Posts: 697
    Thank you, Totte.
    Then how I remove that Plug-In?
    Thank you, Totte.
    If you installed via DIM, remove it via DIM.
    If you installed it via installed and did save a deleter, use that.
    Otherwise, look in /Applications/DAZ 3D/DAZ Studio 64.bit/plugins and maybe you can find it and just put in on your desktop (in case it was the wrong one)
    Thank you, Totte.
    Thank you,Totte.
    I installed almost all products using DIM.
    But I do not know which products to un-install.
  • JaderailJaderail Posts: 0
    You can Use the DIM to uninstall them, but you will need the DAZ Store names to do that.
    There is a NEW Texture thing that does work in DS4.6 now in the store... it is ONLY for animations so remember that.
    And in DAZ Studio 4.5+ the figure setup tools are built in, you do not need any of those tools now. They are part of the main program.
    Check in your Products Library for Plugins that do not say DAZ Studio 4+ compatible and note down the names. If you installed them use the DIM to uninstall them.
