Aiko 3 morphs in DS 4.6
Taoz
I can't find the Aiko 3 morphs in DS 4.6, under Shaping. They're all there in PP2012, same runtime (they load automatically with he figure).
Any idea why they're missing?
Also, I see an "!All SP (Stephanie Petite) Body INJ" icon in the Aiko 3 Pose folder, is that supposed to be there?
Parameters pane > General
You also get more as you click on different body parts.
The S3 injection is so A3 can wear S3's clothes.
Hm, you're right, thanks. Those that show up under shaping when you click on the body parts seem pretty useless though as they're partial morphs.
I don't even use the shaping tab since everything can be found in the Parameters pane anyways.
Always? That would indeed make things simpler.
The thing to remember with Poser figures is that they are a collection of props held together in a null, the null contains the master control dials while the props hold the actual morphs, so yes they do look like partial morphs if you have a prop selected and dial up a morph, as that dial only works on that prop.
The problem with the Gen3's is that their master control dials don't have any grouping, so DS4 dumps them under General, and as it hasn't realized that they are part of the morph system it doesn't "tag" them properly, so nothing shows in the Shaping tab.
When it comes to Poser figures stick with the Parameters tab, as the Shaping tab really wasn't designed for them.
