Morph to remove inner thigh bulge ?
AnimAnim Posts: 241
edited March 2020 in The Commons
Hi,
is there a morph that can smoothly eliminate the inner thigh bulge?
I tried various leg packages, even Killer Legs, but more or less they don't work very well, especially when combined with thinner legs.
Any help is appreciated as this bulge looks so ugly to me.
661 x 681 - 98K
Post edited by Anim on
  • xyer0xyer0 Posts: 6,518
    Killer Legs is mainly for lower legs. Shape Shift has two Thigh Inner morphs, and I remember seeing a thigh gap morph in Studio, but I have all the morph packages, and I don't know which it is from. If no one answers you within my render time, I'll check it and let you know.
    EJ Body Shape and Details has one. It's called "Abductor Gap" (middle of the third row from the left).
  • AnimAnim Posts: 241
    Thanks for the tips. I have shape shift but it does not work well for the purpose, same with other packages.
    Regarding EJ Body Shape and Details: I have muscularity morphs with abductors. They are good at emphasizing the muscle but not good at hiding the bulge when at minus values. This bulge seems to be there as simulation of connective tissue and fat. Maybe somebody has an example picture of EJ morphs? In the ad pictures the legs all show the bulge.
    If no one beats me to it, I'll test it. But you're comparing a muscularity product (which, naturally, would increase size) to a product that has "gap" in the name of its morph. However, I know I own at least one morph available that will give you exactly what you want, but I'm consigned to CPU only at the moment, and this may take a bit. If it's urgent (and what's not), you can drop EmmaAndJordi a message and ask them directly if the morph does what you desire. They're very nice people.
    Very kind yes, thanks.
    It's not urgent.
  • i53570ki53570k Posts: 235
    edited March 2020
    GHD Somebody also has some thigh inner and outer morphs.  One of the promo pic looks like might be what your are going for.
    https://www.daz3d.com/ghd-somebody-morphs-for-genesis-8-female-s
    Post edited by i53570k on
    I will have a look.
    OK, sorry for the lack of images, but my Daz computer is not on the internet.
    If you have this Killer Legs product and have tried its morphs called "FK-Thighs Gap Closed 1" and "FK-Thighs Gap Closed 2" (both negative values) their effect is similar but not as dramatic as GHD Somebody: "GHD Thighs Inner Firm" (positive value), which only affects the top part of inner thigh (for a classic thigh gap). EJ Body Shape & Detail Morphs' Abductor Gap affects the exact same region---but not the entire length of the inner thigh.
    As you've already seen, Shape Shift's "Thigh Apart" achieves space between thighs by changing the relative positions of the upper legs (bowing the hips).
    That's all of my thigh gap morphs. Perhaps you can dial in the lower body of the Daz Originals Body Morphs' Emaciated morph if you have Zev0's Body Mixer, which allows the upper and lower body morphs of that pack to be used independently. All the best.
  • nicsttnicstt Posts: 11,715
    edited March 2020
    https://www.daz3d.com/shape-shift-for-genesis-8-female-s
    It would be good if you could show us the shape you require, as the area is not so helpful.
    Is that something like what you want? I've linked the product, and the image shows the morphs used; the pose is added purely to reflect the pose you posted.
    If you're expecting one morph to do what you want, not only are you going to be frequently disappointed, but you library of morphs is going to become unmanagable.
    I mainly use Daz morphs, and where a shape can be better sought after, look to the linked product above.
    I even make my own when required, but the shapes possible with just the two mentioned are huge.
    1253 x 869 - 124K
    Post edited by nicstt on
  • McGyverMcGyver Posts: 7,103
    Thigh bulges seem to be fashionable this season...
  • CinusCinus Posts: 118
    @Anim,
    Attached is a duf file with a base Gen 8 character and two morphs I created for adjusting the inner thigh. "Adjust Inner Thigh - Left" and "Adjust Inner Thigh - Right". The morphs should be under Parameters->Morphs.
    The attached pictures show what the base Gen 8 character looks like before and after the morphs are applied.
    If you want to save the morphs for use with other Gen 8 characters, then do File->Save As->Support Asset(s)->Morph Assets. Expand "Genesis 8 Female" then expand Morphs and select the two inner thigh morphs and click Accept. They should then be available for all your Gen 8 characters.
    I have a lot of morphs on my machine, so you may get a bunch of "missing file" errors when you open the duf file, but the Inner Thigh morphs should load.
    900 x 780 - 192K
    900 x 780 - 76K
    duf
    duf
    Gen 8 Inner Thigh Adjust.duf
    112K
    @Cinus
    this is amazing, thank you. Exactly what I was after. Seems so, I am not the only one who was unhappy with this bulge.
    It is time to intensify my knowledge of morph creation. I bought so many morph packages (and they do a good job), but in the end there is always a detail that they don't cover.
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,673
    I am curious just how many muscular women actually have thigh gaps devil
    maybe on bodybuilding shows after the rigorous dehydration and diet regime
    skinny builds with the right skeleton certainly do
