Daz Studio (32 or 64 Bit) and Bryce 7 do not work with Mac OSX 10.9 Maverics
Any plans to up grade this? Hexagon is probably also included here. Thanks in advance.
    edited March 2014
    Bryce does not work with any OSX > 10.6. This is stated on the Tech Specs, and I believe also on the product page.
    I haven't heard that DS doesn't work on the latest, others are using it.
    Post edited by Chohole on
    DS does work in 10.9 -- what problem are you having and what version of DS?
  • TotteTotte Posts: 15,115
    DAZ Studio 4.6, Hexagon and Carrara 8.5 all work on OS X 10.9
  • edited December 1969
    Glad to hear it works for all of you. When I start up the, the 64 bit Daz Studio crashes right away. Here is the crash log:
    Process: DAZStudio [1429]
    Path: /Applications/DAZ 3D/*/DAZStudio.app/Contents/MacOS/DAZStudio
    Identifier: com.DAZ.DAZStudio
    Version: ???
    Code Type: X86-64 (Native)
    Parent Process: launchd [147]
    Responsible: DAZStudio [1429]
    User ID: 501
    Date/Time: 2014-04-29 10:33:22.940 -0400
    OS Version: Mac OS X 10.9.2 (13C1021)
    Report Version: 11
    Anonymous UUID: D1A9450C-D0C7-ABF1-40F2-6558DF9A4AFD
    Sleep/Wake UUID: 82504477-2E50-440F-9956-D0BCCCE00862
    Crashed Thread: 0
    Exception Type: EXC_BREAKPOINT (SIGTRAP)
    Exception Codes: 0x0000000000000002, 0x0000000000000000
    Application Specific Information:
    dyld: launch, loading dependent libraries
    Dyld Error Message:
    Library not loaded: @rpath/libdzcore.dylib
    Referenced from: /Applications/DAZ 3D/*/DAZStudio.app/Contents/MacOS/DAZStudio
    Reason: no suitable image found. Did find:
    /Users/mikeperry/lib/libdzcore.dylib: mach-o, but wrong architecture
    Binary Images:
    0x7fff61b84000 - 0x7fff61bb7817 dyld (239.4) <2B17750C-ED1B-3060-B64E-21897D08B28B> /usr/lib/dyld
    Model: iMac14,2, BootROM IM142.0118.B00, 4 processors, Intel Core i5, 3.2 GHz, 16 GB, SMC 2.15f2
    Graphics: NVIDIA GeForce GT 755M, NVIDIA GeForce GT 755M, PCIe, 1024 MB
    Memory Module: BANK 0/DIMM0, 8 GB, DDR3, 1600 MHz, 0x80AD, 0x484D54343147533641465238412D50422020
    Memory Module: BANK 1/DIMM0, 8 GB, DDR3, 1600 MHz, 0x80AD, 0x484D54343147533641465238412D50422020
    AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x111), Broadcom BCM43xx 1.0 (6.30.223.154.63)
    Bluetooth: Version 4.2.3f10 13477, 3 services, 15 devices, 1 incoming serial ports
    Network Service: Ethernet 1, Ethernet, en0
    Network Service: Ethernet 2, Ethernet, en1
    PCI Card: pci1b4b,9182, AHCI Controller, Thunderbolt@193,0,0
    Serial ATA Device: APPLE SSD SD0128F, 121.33 GB
    Serial ATA Device: APPLE HDD ST3000DM001, 3 TB
    Serial ATA Device: HGST HDS724040ALE640, 4 TB
    USB Device: BRCM20702 Hub
    USB Device: Bluetooth USB Host Controller
    USB Device: FaceTime HD Camera (Built-in)
    USB Device: Keyboard Hub
    USB Device: Apple Optical USB Mouse
    USB Device: Apple Keyboard
    USB Device: BUFFALO Optical Drive
    Thunderbolt Bus: iMac, Apple Inc., 23.10
    Thunderbolt Device: G-RAID with Thunderbolt, G-Technology, 3, 26.3
    It's gibberish to me, but indicates a serious problem.
    Hello, which version of DAZ Studio are you running?
    The error indicates that DS can't locate libraries it wants to load.
    How was it installed? Through DIM or manually?
    Do you have some kind of AV-software installed, those can sometimes decide to prevent applications from loading libs.
    Now I see what it is.
    The lib is: /Users/mikeperry/lib/libdzcore.dylib: mach-o, but wrong architecture, which I think is the problem right there.
    How can it find the libdzcore.dylib in your home in lib that is either 32-bit or PPC (it clearly states wrong architecture).
    That's nothing to do with DS 4.6, you must have some strange stuff installed on your machines, and the library loader dom load Libraries in order of user/all/system from any paths added to a library list.
    Can be remains of an old and trashed DS installation (unlikely with a new OS though)
    Thanks for those tips. I installed DAZ Studio anew, and it works fine now. Thanks for your help.
