Two questions about backing up my library
Hi,
I have two questions about backing up my daz library:
1.) I want to make backups of my custom inventory-structure in the "categories"-section. Is it enough to back-up [...]AppData\Roaming\DAZ 3D\cms ...is everything stored there? :)
2.) Some addons from the store had to be installed inside DAZ seperately. For exaple the morphing-addons etc... I had to run a script or something like that inside DAZ after the download with the manager. Is it possible to back-up the entire library including those installations? Because if I ever have to re-install windows or get a new PC, I would love to just put my library into the new place without looking which addons from the growing library require a second installation.
Thanks!
  • Richard HaseltineRichard Haseltine Posts: 111,834
    1) yes, but as a ward agaisnt database corruption I would also use the Content BB Maintenance dialogue (Content Library option menu - the lined button in the top corner or right-click the tab) to Export Userdata, which will place a .dsx file in /Runtime/Support in your first content directory.
    2) Plug-ins, and some scripts and shaders, have to be installed on the system - they can't just be backed up. Other than that, if you are thinking of the ExP utility for characters like Victoria 4 (whicu are not needed in DS if you use PowerLoader) then they make chnages to the content directory that will be included in your back up.
  • BaudolinoBaudolino Posts: 13
    Thank you! Didn't know about the Content BB Maintenance dialogue... I will use that method!
