About the Millennium Horse
BellaBella Posts: 452
Hello, I have just got the Millennium Horse and I was trying to load the breeds listed there:
Thoroughbred
Arabian
Mustang
DraftHorse
Zebra
Donkey
Mule
Shetland
But I see this Horse is like the Millennium Horse LE I had already...I think I miss something!
How do I "do" that breeds? and what about the Millennium Horse Bundle?!
Thank you!
    I must say, I had a bit of bother myself, but I found them!
    Select the Horse (Millennium Horse SR1) in the Parameters pane, then go to 'General', and you will find them all listed there. Hope that helps you?
  • BellaBella Posts: 452
    ok that helps a lot! thanks!
    and what about the textures?!
    thanks again!
    edited March 2014
    The materials for the Mil Horse are in the same Runtime folder that you load the horse from, under 'Pose' instead of Figure.
    Click on the Pose folder, and you will find them under 'MAT Mil Horse'. There are various mats for Fetlock, Mane and Forelock etc.
    EDIT
    Quick edit, if you install using DIM, then go to the Installed tab, select the item, right click, and select 'Show Installed Files' that will show you where they all are, and they are clickable links too.
    Post edited by JimmyC_2009 on
    Ok, thank you, you helped me a lot!!
