How to set up a noon sun in sun-sky rendering enviornment?
kar98kdasinikar98kdasini Posts: 56
edited March 2020 in The Commons
Hello, DAZ community.
So despite my joined date and post number, I am actually a newbie to rendering due to the limit amount time playing DAZ studio.
What I need is the sun at noon so that the shadow is correctly reflected instead of in the screenshot.
Here is my screenshot and sorry for my imperfect English.
Edited: Moved to The Commons bcs there have the most number of discussions and comments...
1920 x 1017 - 216K
Post edited by kar98kdasini on
  • FishtalesFishtales Posts: 6,236
    You have it set ti 15/3 which is March, try changing it to June 21st which is midsummer.
  • y3kmany3kman Posts: 899
    If your goal is to just have the "sun" directly above your character, just set both latitude and longitude to zero.
  • Uhm, I thought setting the time at 12:00 pm should have worked.
    Thanks, will try.
  • Silent WinterSilent Winter Posts: 3,965
    Or use the render preset sun dial (Should be under 'Render Presets: Iray) - then you can move the 'sun-chain' and point it whichever way you want
    Thanks, will try.
    It would but the lat/long setting is for the northern hemisphere. If you want it directly overhead at noon set the lat/long to the Equator.
  • Or use the render preset sun dial (Should be under 'Render Presets: Iray) - then you can move the 'sun-chain' and point it whichever way you want
    How to use the render preset sun dial?
    I can't adjust its position.
  • NorthOf45NorthOf45 Posts: 5,920
    Expand the Sun Dial element in the scene until you see "Sun Chain", and select it. In the parameters tab there are two adjustments to play with, Elevation and Azimuth. You can also use the Universal or Rotate tool in the viewport with Sun Chain selected. Or even use the Active Pose tool directly on the Sun node, but that is a little awkward.
  • AlmightyQUESTAlmightyQUEST Posts: 2,006
    Another option that may work for you, create a camera to position the sun, and position the camera above looking down at the figure (if you want it tilting a little in front or behind the figure, it's easier to "see" where the light hits). On the environment setting, go to the Sun Node option and select that camera as the sun node.
  • nonesuch00nonesuch00 Posts: 18,882
    The sun won't be really directly overhead unless you live on the equator and it's spring or autumn solstice. If you live on one of the tropic lines it'll be summer (Cancer) or winter (Canpricorn) solstice. The rest of the year it'll travel north - south / south - north between the two tropics lines.
  • Thank you very much for all the replies.
