Loading time of Genesis 8
Hi, since friday I have following problem;
I load my G8F but the loading took round about 15min. The londing started normal until the tag "Reading asset" came in and the block is in the first quarter it stops. When I click in the progam gets clouded and in the headline the mesage came (no answer).
I checked my computer for problems, less space, or not working parts but nothing wrong with the hard wear.
What is wrong or what can I do to increas the loading?
  • Matt_CastleMatt_Castle Posts: 3,249
    You need to look at your program log. If the time has jumped up significantly, there's probably a problem with some asset that's causing a load of errors when it's loaded, but we won't know what without you looking in your log.
  • ExperimenterExperimenter Posts: 164
    edited March 2020
    Here is the latest logfile from my problem.
    I reinstalled G8F, DAZ Studio, and the face enhancer as it was written in the log file.
    I checked the path from the log file for real dublicats, but not same names.
    What can I do now?
    I had to save it as a zip file to upload it.
    zip
    zip
    log.zip
    522K
    Post edited by Experimenter on
  • TheKDTheKD Posts: 2,711
    That auto face enhancer is throwing a ton of errors up, I would uninstall that.
  • xyer0xyer0 Posts: 6,504
    You have to manually uninstall it as well as uninstall it with DIM, the author says.
  • Is there an unistaller or do I have to delete it by myself?
    Can I install it again after the manual delete? I had the problem with another program; after I delete the files I installed it again but it did not started because I deleted too much.
  • memcneil70memcneil70 Posts: 6,092
    There is a lot of discussion and instruction in the commercial thread which is quiet extensive, but if you start at this page https://www.daz3d.com/forums/discussion/317856/auto-face-enhancer-commercial/p20 D.Master gives detailed instructions on how to uninstall and reinstall correctly. I had the same problem and followed his steps and fixed my systems.
  • Thank you, it works. The loading is back to normal.
