Help regarding Tea Party Kids
KharmaKharma Posts: 3,214
I had the DS files installed for this product and went to load the Preload.daz files and it tells me it can't find the files so thinking I needed the ps files also I installed those plus the ps versions of the other required products. It still won't load the preload and throws up the same error message about can't find some files but not which ones. And yes I already checked to make sure files were installed and paths were correct. the Poser files load the preset no problem.
So since I have DIM set for DS files only, how in the world am I supposed to know if I also need the Ps files also? Even tho in this case they still didn't help to load the product.
  • JaderailJaderail Posts: 0
    DIM is supposed to auto download all files needed for the version you have checked. If it does not please report the file(s) so that sales can have the item(s) updated to work properly.
  • KharmaKharma Posts: 3,214
    Ok will do, I thought DIM was supposed to take care of which files you need but maybe this one got missed or it was user error, but I checked all pertinent files and it still didn't work so will report it. thank you
  • frank0314frank0314 Posts: 15,116
    edited March 2014
    Your not really gonna know if it requires the Poser files as well. To get some of the DS files you need Poser checked off and you can field through and hide or not install the ones you want. A safe way to tell, if the DS and Poser files are the same size then they are independent if they are way off then it probably needs both.
    Post edited by frank0314 on
  • fixmypcmikefixmypcmike Posts: 19,742
    DIM should deliver all the packages you need without having Poser selected, but some products aren't tagged properly -- they've fixed all the ones I've reported, but of course I don't own every product.
    I did install the poser files for all and it still didn't load from the TPK preload1.daz file or TPK preload2.daz file under Das studio formats. The preset from the poser library will load which is TPK preload1.cr2. I do have other files that are .daz files that do load, so I am not sure if this file is supposed to load the scene or if I have to load the cr2 then the daz file, which seems not necessary, I don't want to report something not working if it's just user error. I was hoping someone who had htis item could try and see if it works for them.
