Daz Studio 4.12 Pro hair moving with expression...
Alicia Hair model
Hair is moving when changing facial poses (eyelids, open mouth etc etc)
Is there a way to turn this off?
I tried turn off smoothing literations and collisions, unparent hair. Don't have any other ideas lol
put a ticket into Zendesk?
Do other hairs not move? If you expand the bone hierarchy for the hair n the Scene pane does it have all the expression bones below the head? If so you could either delete them, with the Joint Editor tool, or zero their weight maps, with the Node Weight Map Brush tool, and see if that eliminated the issue. But yes, if it's just this hair I would open a support ticket to report it.
It worked! Deleting bones on the eyes. I have to work on it more and delete only proper bones becouse the hair toally messes up if delete too many.
Is there maybe a way to copy bones from other hairs to this one?
Yes, but. You could use another hair as the Source figure in Transfer Utility but it would probably have limitations of its own. Still, as lng as you don't save it's safe to experiment. I would, however, encourage you to file a support ticket over this.
