WARNINGS in the log.txt During Start up... How do I clean these up?
I am showing these WARNINGS in the Log file just from Starting up Daz 4.12
Anyway insight as to how to clean these up?
2020-02-29 10:41:31.977 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(419): Could not add path: "C:/Users/DAZUSER/AppData/Roaming/DAZ 3D/Studio4/shaders/iray". Due to unknown error -2
2020-02-29 10:41:31.982 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(419): Could not add path: "C:/Users/DAZUSER/AppData/Roaming/DAZ 3D/Studio4/temp/shaders/iray". Due to unknown error -2
2020-02-29 10:41:32.430 WARNING: 3DConnexion Plug-in Error: Could not create Device, CoCreateInstance failed
2020-02-29 10:41:34.110 WARNING: QLayout::addChildLayout: layout "" already has a parent
Any help would be greatly appreciated!
  • BejaymacBejaymac Posts: 2,002
    They aren't "hurting" performance so no real need to worry about them, can't remove all of them so if they bug you being there then you might have problems.
    First one you can simply create the missing folders
    Second one will always be there, only four folders are "safe" in the temp folder, any others will be deleted every time you close DS.
    Third "Help > About Installed Plugins" remove the check from the 3D Connexion plugin, select "OK" and then close DS, next time you start DS that plugin will no longer be loaded.
    The last two are I think being generated by the UI and as such there's not much you can do about them.
