Hair Missing in Render Preview
I bought the MRL dForce Long Layered Hair for Genesis 8 Female with Colour Mixing and trying to use it it shows up great in texture shaded but when I go to Iray preview it's gone. Just the black base on my character's head.
  • I am also having the same issue.
  • QuixotryQuixotry Posts: 919
    dForce hair doesn't show in preview modes by default. I don't have that particular hair, but I imagine it's set up pretty much the same way as other hairs of the same type. Try this:
    Select the hair in your scene tab. Go to the parameters tab and change Preview PR Hairs to 'On.' Then change Line Tessilation to a value higher than 0. I usually use 2.
    That's how I get dForce hair to show in a preview render, but I leave those settings off as much as I can because Daz Studio gets very laggy and slow with the hair showing fully like that. It will probably slow your DS down as well. I only turn those settings up if I want to check colors and how the light looks on the hair, then I turn them back to their default settings until my final render. I hope that helps!
  • That helps a lot. Thank you very much.
