LECS for G8 female problem
3D Vitality
Hi ,
I refer to this product: https://www.daz3d.com/lecs-for-genesis-8-females and especially to that promo pic https://www.daz3d.com/media/catalog/product/cache/1/image/9df78eab33525d08d6e5fb8d27136e95/l/e/lec_promo_5.jpg
As you can see in the promo pics, there is a crisp clear normal / bump map which defines the structure of the head, helmet , and so on. Now if you look at my attached pic you'll see a bad render result with very smooth normal/bump
I loaded the G8 basic female, add all the items, morphs and materials of the product and I get a lousy output compared to the promo. And I didn't find the error so far. For me it seems that the mesh of the G8F is not dense enough to produce a good result with the LECS product.... but clearly this cannot be the reason, as the promos based on the same mesh. And I can't find the place to regulate the depth of the normal /bump ... which is perhaps another reason for the lousy output.
I hope you can enlighten me with some ideas and hints on that topic...
Thanks in advance!
Think I found my mistake... mesh resolution for G8F. It was not high enough. Set it higher and it worked. So problem solved and lesson learned
