no default scene on startup
i just installed DS 4.6 pro and when i start it there is no default scene loaded.
i just get an empty workspace
i haven't used DS in a long time ....
but is't there supposed to be a default startup scene with the genesis figure and a beach scene or something ?
Not always. It depends on your settings. You can tell DS to load a figure or scene when you start fresh in the preferences menu.
ok thanx for the help !! :-)
The Normal start up is just Genesis loading no props or lights or stuff....
You can also customize the Startup Scene to your liking. I prefer not to have Genesis automatically load, as it's not the only figure I use. I do, however, prefer to have my preference in cameras and lights load automatically each time.
Once you've figured out whether there's a set of lights and cameras you'd like to use each time, you can resave the scene to your My Library > Scenes folder so that it loads automatically each time you start up DAZ Studio, as long as you've set it up in Preferences to do so.
