dForce Side Bob Hair
Coryllon
I'll be honest, I have no idea how this works. I posed it, but it doesn't render, not even with materials. I apply the shaved head version, I pose it, I add shaders try the IRAY preview and get nothing. Any help would bve awesome
Post edited by Coryllon on
By default dForce hair doesn't appear in Iray preview (to save resources), only in actual iray renders.
To make it appear in Iray preview you need to switch "Preview PR Hair" to "on" in the parameters for the hair. It's in General > Line Tesselation parameters group
didn't help, still doesn't show up and when I just hope for the best and render it, I get all the multi-colored lines
I think you may need to set a higher value to the "Viewport line tesselation sides" parameter too.
(I don't have that hair so I can't try it myself unfortunately)
Gave up entire on preview, I cannot get it to show up any time; or if it is. it's hiding behind the posing lines... if I turn them off I see no hair at all.
ok figured out the problem.. if you don't select the hair AND the base (parented to the hair) no materials will show up and you can't render anything...
