Help with Ultra Scatter Pro - instances floating in air
Trying to learn how to use Ultra Scatter Pro and I'm having difficulty in keeping replicated objects on the ground. The "scattered" objects are floating in air above the orginal item and I can't figure out why. Please help!
Thanks in advance!!!!
  • barbultbarbult Posts: 27,498
    It depends on where the geometry origin is on the item you are scattering. Try different options for the Origin on the Rotation tab. You may need to check "Ignore origin transform", too. This is described in the PDF manual. Experiment.
    edited February 2020
    Here is a thread I created to document some UltraScatterPro experiments and tips. You might enjoy looking through it. It is kind of old now, and a later update to UltraScatter Pro added the ability to select the unit of measure for the numeric entries.
    Post edited by barbult on
    Thanks, I'll check it out and keep experimenting. So far nothing I've done with the settings has worked.
    What product/object are you scattering? If I own it, I'll try it and see what's up.
