Not sure if I downloaded Bryce correctly?
I'm sorry - I believe my last post about this didn't go through correctly - I can't find it anywhere. So pardon if this is a repeat.
I have, in my account, the Lightning.exe set of files and the BryceProContent.exe as well.
However, when I install and let the installation path point to wherever it seems to default to - it says Bryce can't be found. So, if I'm not mistaken I haven't properly downloaded the actual Bryce 7 Pro application itself?
I keep going in circles in my account's Product Library. The files are there - and I've downloaded those two. However, the Lightning and Pro Content aren't the base program, right?
Where do I go to get that base program downloaded?
-Thanks
You should find that, under Bryce 7
In my product library it says
Bryce 7
Bryce 7 Pro Upgrade
Hi Danmowry,
This document by Horo is very helpful. http://horo.ch/docs/mine/pdf/BryceContent_v4.pdf
Also, if you want to check the version you have installed once you have got it running Bryce 7.1 Pro - Help, About Bryce - a short video by David Brinnen
You will also find very many Bryce tutorials here on diverse topics, http://www.bryce-tutorials.info/
