Is there a way to change the resolution of Daz studio 4.12? (not the render resolution)
Ok, so I've tried searching, but got no where, so I'm hoping someone here has a solution.
My problem, I have a 32" monitor and Windows 10 recommends a resolution of 2560 X 1400 with a 175% font scale layout. These settings work well for almost everything, except for Daz. Unfortunately, these settings make it feel like I'm still using a 20" monitor and the text in Daz is a bit fuzzy, as well as the overall layout feels cramped due to the scaling. The thumbnails for example are almost 2" instead of a prefered 1". I really don't want to have to go into Windows setting and adjust the scaling each time I switch between Daz and other programs. I'm really hoping there is a way to set Daz's resolution in program, but I couldn't find anything so far.
Thank you for any suggestions.
Right-click on the application icon, select Properties, go to the Compatibility tab and check Disable display scaling
Thank you, It worked. It now feels like I have doubled my work area, and is easier to manuver around.
