Somehow Genesis 8's tongue is permanently visible, I can't hide it.
solved
edit: nevermind. Genesis 8's default tongue is hidden. The extra tongue must be some kind of shell that belongs to the lickalicious third party figure (tongue). The solution is to delete lickalicous tongue and re add it. The solution is to select the other third party shells attached to G8F (example anatomtical shells), then run the shell fix script from lickalicuos folder.
What could cause Genesis 8's tongue to become permanently visible? When I try to hide Tongue 1,2,3,4, it doesn't go away.
When I hide Genesis 8, the default G8F tongue doesn't go away either.
I do have a third party product installed called Lickalicious which adds a new tongue, but I don't understand why the default G8F tongue is permanently visible. When I used the control key to hide and unhide Genesis 8, it made the default G8F tongue visible, and now I can't hide it no matter what I do.
Thank you so much! I know this is an old post, but you have helped me save so much time and hardship that you deserved a thank you!
