Is there a way to have Two Tabs?
anthony.luigi_05ebfcd7e7
Hello,
Since purchasing a 2nd monitor I was hoping there was a way to be able to undock my Content Tab move it to the 2nd monitor and create another withing the DAZ interface.
Unfortunately, I can't figure out how to have two of the same tabs. As soon as I try to create another in DAZ the 1st one disappears. Is it possible?
A
No, each pane is available only once.
Get the beta version and use that for your other display of the other tab.
What is the reason, out of curiosity, as to why you want two content tabs open? I assume you might be looking for an easy way to move things around, or just want to see more than one folder at a time.
You know that you can un-dock the panes, right?
you can also drag and drop from windows explorer
I do this a lot
I do a lot of posing with male and female characters in the scene together. Sometimes G3 and G8 as well. I would like to have my poses folder open and avaialble for male and female ready to select at the same times. Tired of opening one then having to go through my contents to find the other. I have two monitors so it would be great to have multiple content tabs open at the same time :(
Thanks for chiming in!
Could always try using Smart content and Content library.
As long as the items are smart content compatible.
