Reset or redefine scale parameters to prop/object for proper scaling ?
dream-weaverdream-weaver Posts: 155
edited February 2020 in The Commons
Is it possible to reset/redefine the scaling parameters to an existing prop?
I have a prop from a set which I would like to change the scale individually in length and width. But the object is not placed according to world coordinates, it's already angled. I guess that's the reason the scale parameters are off. I can't change the scale properly in length and width.
Post edited by dream-weaver on
  • If the object is modelled off-axis then I think you would have to rotate it so t alligned to the axes, export as OBJ, reimport, and scale. t would probably be easier to use a real modeller - Hexagon will let you align the axes to a selected polygon, as I recall, which would be just what you want as you could then scale it without rotating.
  • Thanks, exporting/importing worked!
