Measure Metrics pane location?
Hi this is my first post so I will cut right to the chase :)
I just bought Measure Metrics for Daz Studio 4.6. I have found where all of the measuring apparatus are (People - Genesis Female 2 - Measure Metrics) but that is it :/
My question is where do I see the measurements?
I have tried looking for the Measure Metrics pane but I cant find it:/
Thanks
  • rbtwhizrbtwhiz Posts: 2,485
    Have you entered your serial number in the Help > About Installed Plugins... dialog yet? The Measure Metrics pane will not be available from the Window > Panes (Tabs) menu until you do.
    The Installation page of the Measure Metrics documentation covers this in more detail.
    -Rob
  • 00t00t Posts: 10
    edited March 2014
    Ah! Here's a stupid question, where do I find the serial number for my copy? Thanks rbtwhiz!
    EDIT: I try opening the stand alone installer but keeps saying "The installation path for DAZ Studio could not be found".. and so on
    EDIT 2: Found it! Under my serial numbers! Thanks!
    Post edited by 00t on
  • frank0314frank0314 Posts: 15,098
    edited March 2014
    Which installer are you trying to install? Are you trying to install with DIM? If your trying to install the Public Release file then you have to have the beta installed for that one to work. If your installing manually your serial number is listed in your My Serial Numbers in My Account. Be sure to scroll through each page.
    Post edited by frank0314 on
  • 00t00t Posts: 10
    The beta didn't work for me, manually installed or DIM. But the other version works. I just couldn't figure out why it wasn't activated. Now I know I have to punch in the serial number :). Thanks for the quick replies. Hope kully_badman got it to work too.
    If you install stuff through DIM you don't need to enter serial number. At least not to my knowledge.
    Correction, you have to manually install the serial number in yourself. For some reason I thought DIM did it for you since it has for other plug-ins. I just checked mine and noticed I had to enter it in.
  • dramenondramenon Posts: 52
    edited November 2014
    Install Manager gave me some problems and had to force the install on all the components...
    Post edited by dramenon on
