Hair color altering?
So I picked up Chace Hair. cause I love the Captain Marvel Endgame style of it. I wanted to use it on my female knight. Anyway. The blonde it toooo white. Is there anything I can to to add more yellow or darken it up? am I missing something? all the other colors look right in spot render. except for this one
2560 x 913 - 1M
Select the hair and open the Surfaces pane, then go to its Editor tab. The first thing to try would be darkening the Base Colour by clcking on the colur chip nd picking a slightly drker, more yellow colour..
OMG your right! for some reason for the blone they are all set to white! No wonder!! thank you! messing with colors now. So much little stuff to learn. Thank you!
That's normal. What you usually get is an image that supplies the actual colour, and the colour picker tells Daz what colour to overlay it with. White means do nothing, leave the original colour alone; black will black it out entirely; and other colours will add a tint to the original.
Adding grey to the diffues channel is a good way to darken and tone down over bright colours. It's often a good idea when using objects in Iray that weren't designed for it.
