Angel for V4 - Issues
jdavison67jdavison67 Posts: 690
Is it just me, or is this a glitchy product?
Adding the morphs seems to be hit or miss.
The hair will not fit to the character, I keep getting the error show below, in my attachment.
I tried loading other hair, to this character, witch has a V4 base, so any hair that fits a V4 should conform, and they do not conform to it.
I'm baffled, and agitated that such a pricey product is this problematic.
JD
528 x 367 - 79K
    edited March 2014
    How are you trying to fit it? HR2 is prop hair that is parented to the figure rather than autofit.
    Post edited by Lissa_xyz on
  • jdavison67jdavison67 Posts: 690
    It isn't parenting for some reason.
    If I change the character pose the hair is getting left behind.
    I'm going to try uninstalling and reinstalling.
    JD
    OK,
    I loaded a standard V4.2 character with only the M++ morphs, and I was able to get the face to load finally with out the lower jaw sticking out.
    Then I was able to get the angel hair to conform, but it took three attempts to fit it.
    Something about this set is a bit off, but I guess I can work around it.
    Not the best quality kit I have purchased. A shame really...
    JD
    edited March 2014
    Did you use the V4 fit morph? There should be some additional fit morphs included
    Post edited by Chohole on
  • nightwolf1982nightwolf1982 Posts: 1,342
    Go to Pose > Angel V4 > Angel Hair Fits to find the hair fitting files. There's also a set of fit magnets available here in the store. As to your problems loading the morph, it may be a conflict with the Beautiful Bends product. This set has been out almost as long as V4, and it may not be compatible with some of the bend fix products out there.
    If you are running into morph problems with Gen4 figures, it is sometimes a good idea to rerun the ExP bat (windows) or cmd (mac) files found in the !DAZ folder. Just doing this can often fix any number of issues. Be sure Poser or DS (whichever app you are using) is closed before you do this. It will not fix anything if you have V4 loaded and the app running at the time you do it.
  • SzarkSzark Posts: 10,634
    this is only for manual installing as Frank said in another thread DIM takes care of that now.
  • Richard HaseltineRichard Haseltine Posts: 111,996
    Well, if this is a maintenance task rather than an installing new content task then DIM's running the command after installing won't help.
    So it is needed on certain occasions...yes?
    edited March 2014
    It shouldn't be, but it can be useful if something has ganged agley.
    Cheers, just want to make sure the info was correct.
    Needed regularly? No. But V4 morphs failing to inject or function is a known issue with Poser that is often fixed by running the ExP. I never had issues witih DS3A but have run into the same problems once or twice with DS4.x. This issue has nothing to do with new installs.
    Live and learn thanks.
