Is there an "Invisible" material?
I'm trying to hide specific surfaces in a garment. If I turn Opacity to 0, it is usually completely hidden in 3Delight, but in Iray there is sometimes a 'ghost' in the image. Is there a maretial that can be applied that can get rid of them?
If not, what is the correct way to create one? If I go through and eliminate all textures and set all colors to black, will that do it?
  • SimonJMSimonJM Posts: 6,100
    Be sure that all maps are also removed from the material zone and things like refraction are set to 'default' values (I woudl say zero-ed out, but I htik default refraction id 1, etc.) so, yes, your 'paint it black' suggestion would/should be good.
