come on!!!
konkon Posts: 389
Install Manager cannot find a required path. The installer for "pwGhost for DAZ Studio 3" requires that the installed path for "DAZ Studio 3 Adv, 3" be defined. Make sure that a path for this application is present on the "Applications" page of the "Settings" dialog, then try again.
  • fixmypcmikefixmypcmike Posts: 19,742
    Do you have DS3 installed?
  • konkon Posts: 389
    no I have Daz studio 4. whatever.
    You should set your download filters to exclude DS3. You only need to install the DS4 version.
  • konkon Posts: 389
    ok but some of my downloads wouldn't down load unless I changed it
    Which ones? If they aren't tagged properly, please submit a ticket to get them fixed.
  • SzarkSzark Posts: 10,634
    edited March 2014
    This is how my DS4.5 only DIM filters are set at
    as you can see PW products are tagged DS4
    575 x 538 - 178K
    563 x 929 - 245K
    Post edited by Szark on
  • konkon Posts: 389
    I send them tickets and it doesn't change anything.
    Can you give examples of items which show up under DS3 but do not appear under the DS4 downloads?
  • konkon Posts: 389
    Cute3D Rose Heels
  • JaderailJaderail Posts: 0
    Here is a HINT, ALL the DS3 plugins that do not work in DS4. Like Light Dome Pro2, MoodMaster and as just seen pwShaders for DS3.
    The user is going to be asking why they do not work very soon, and how to fix them.
    DEAR User ALL DS3 content THAT can work in DS4.5+ will install in DIM set to DS4.5+. Any content that ONLY lists with DS3 ticked in the DIM is a DAZ Studio 3 only FILE and will not function in DS4.5+ at this time. Installing DS3 only files into DS4.5+ will only take up disk space and cause you heartache they will not run in the New version of DAZ Studio.
    Cute3D Rose Heels
    Some Items are not DIM ready yet for DS4.5+ but you will find that the pwShaders for DS3 do not function in DS4.5+ as I have stated.
  • Miss BMiss B Posts: 3,071
    edited March 2014
    Cute3D Rose Heels
    Cute3D Rose Heels is a Genesis 1 product, so wouldn't/shouldn't show up as a DS 3 item.
    I have it installed in my DS 4.0 Pro, and I can't imagine that DS 4.5 or DS 4.6 wouldn't be able to see it if it's installed to the proper folder.
    Edited to Add: I should note that I don't use DIM to install, so that may be the reason I can see (and select) them from my Content Library, as I manually install by unzipping to my desktop, and then moving the contents to the proper folders, as per the structure in the zip.
    622 x 552 - 75K
    Post edited by Miss B on
    Jaderail said:
    Cute3D Rose Heels
    Actually Jade, I downloaded the Cute3D Rose Heels through DIM. I think most of the files that aren't DIM ready are some software plugins.
    I never Checked that One item, I simply mean that I'm still getting new Items in my DIM that are just now showing up from my older orders. That was the only thing I meant. As they get converted to DS4.5+ and OR DIM file format they show up.
