Argh! My Viewport Lines Disappeared!
dracorn
After loading Blenworth, my viewport lines dissapeared.
Usually I go to Window, Style, Customize Style and change the Viewport color. After changing it to dark gray, my gridlines are still missing. I even messed around with making it lighter or darker, and I still can't find my gridlines. Is there another place where they are turned on and off?
If you're referring to the 'Floor grid', blenworth is above the grid, you'll need to move it down to see it again.
If it's not 'on', just to the right of the 'View select', the menu drop down has an option to turn the grid on/off.
