Why does my grayscale displacement map shrink the mesh?
In photoshop I created a grayscale (128,128,128) displacement map.  I used white (255,255,255) to draw some lines.  When I apply this displacement map to a sphere, using the default IRAY surface settings of 1.0 displacement, 0-.10 min, 0.10 max, it shrinks the sphere.
I thought the whole point of a gray scale displacement map is that white creates a popout effect, while black creates indentations, and gray keeps the mesh at it's default height. So why is the sphere shrinking?
    Whit is the raised area, mid grey is flat and black is the lower area,
  • lilweeplilweep Posts: 2,872
    they said they were using mid gray (128,128,128) allegedly.
  • Assuming your rendering the viewport at the same scale, when you overlay the one on the right over the one on the left, it's the same size, so it seems it's working normally.
    Optical illusion because it's raised the white parts?
    Also your subD is at 0, go to 1 or 2, it will be smoother.
  • FlortaleFlortale Posts: 611
    Guys, the UV map was poorly done and it caused problems somehow, I don't quite understand it.  I used a different sphere with a different UV and the problem went away.
