clothing file not found after installing? help
i installed a rendo sweater however when I try to load it on G2 I get an error. Can you help figure out what I need to do?
I extracted the zip file into a folder and then transferred the contentsunder my Daz 3D Library.
Thanks
1154 x 505 - 54K
Post edited by Aristoc on
Does that file exist in the same library you added the sweater to?
I think this is it here. Looks like it's correct? Not sure.
this is what happens after the missing file message.
Hello there again. I decided to extract again....and the manually transfer each individual folder . This worked. THanks so much for looking into this. Appreciated. a lot.
The screenshot of the file location shows a nested content folder.
When installing stuff you are putting the folders in the zip file's 'main content folder' (whatever it is named...content, my library, etc) INTO your library folder...NEVER put that main folder, into your library...Content = My Library = My DAZ3D Library.
starting to get it.Big thank you. Have a nice weekend.
