Spotrender in Viewport, how to save as file?
LoonyLoony Posts: 1,817
edited February 2020 in New Users
Hi...
I hope someone can quick help me, i forgot to change the spotrender  settings and it did render in the viewport, the image is still in Iray, how can I save it now? :(
I hope someone can quick help.
would be soo good, if it would be possible to set new window as standard <_<
I did hope this would work, but its grey ;(
**did killed it by rightclicking in the viewpoert ;(.... thought I get maybe a option to save it..., anyway. would be nice to know IF there is a option to save it...
215 x 350 - 21K
Post edited by Loony on
  • QuixotryQuixotry Posts: 919
    You can do that in the Tool Settings pane (Window > Panes > Tool Settings). With the spot render tool active, change the setting from Viewport to New Window. Then use spot render and it should bring up the rendered section in a new window, and when it's done you can save it as you normally save any render. :)
    506 x 130 - 13K
    Post edited by Quixotry on
  • Spot renders in the viewport can be saved by making a screen grab image and pasting that into an image editor to save the file. One will of course have the entire screen view so some cropping would be necessary.
  • LoonyLoony Posts: 1,817
    I thinked about that, but the viewport is not in the QHD resolution and I wanted to merge the spotrender as a .png into the other scene.
    Oh I know that option haha, I guess you understad/read my problem not good enough :P
    I had the standard Viewport option, because I forgot to change it (you ahve to change it ALWAYS, every time!) and I made a 1:40H render and then it was in the viewport, I looked for an option to safe it... If it was in a new window, then well, then it would be like a normal render :)
    I also checked the %appdata% tmp folder, but there was no render ;( also weird that the software didnt offered me to save the last render, I did try save last draw, but that used only the ugly viewport view and not the rendered preview.
