XprssnMagicImporter for V4 and M4
donalddavisdonalddavis Posts: 95
edited December 1969 in Product Suggestions
I cannot see how to get either one of the two of the items below to work.
I have read the instructions and downloaded the scripts, but the script simply opens another instance of DAZ and returns an error saying I need to select a single object. Which I did before I ran the script.
Please let me know if you have a resolution or face this problem yourself.
Thanks,
http://www.daz3d.com/victoria4xprssnmagic
http://www.daz3d.com/michael4xprssnmagic
  • JaderailJaderail Posts: 0
    That item and the Script was DS3 only I believe. It would need to be Edited with the Code to run in the DS4.5+ SDK now. Just as it did to run properly in DS3A.
  • Richard HaseltineRichard Haseltine Posts: 111,835
    Don't double-click the script in an operating system window, apply it through the Content Library or via File>Merge, though it did need updating for newer versions of DS I think that was done.
    Hmm... I'll check my version of the V4 set. Pretty sure it is DS3 only still.
  • zug22zug22 Posts: 74
    Okay, I'm looking at getting Victoria4XprssnMagic. . . .so does it work in DAZ Studio 4.6 or not?
    Also I'm on Mac OSX 10.9 so I would like a confirm that it works for me before buying.
    If it does I might get the M4 version too. . . .
    Thanks
  • I have the same problem. I can not use. And I an not find in the files the 11 Page Illustrated .PDF User Guide. So I wish the creator gryffnn / Elisa Griffin can fix this.
  • ToBoldlyGoToBoldlyGo Posts: 21
    http://docs.daz3d.com/lib/exe/fetch.php/public/read_me/index/4785/4785_v4xprssnmagic-guide.pdf
    http://docs.daz3d.com/lib/exe/fetch.php/public/read_me/index/8876/8876_m4xprssnmagic-guide.pdf
    The last pages seems to have the answer that it was updated to Daz 4, but does it still work with the current version of Daz 4? Other scripts have failed at certain points (4.12, etc). All the XprssnMagic products are on sale currently so there may be some interest.
    Mr Haseltine, presumably you would have the source code if it needs updating?? Elisa Griffin  / gryffnn doesn't seem to be a Daz member anymore, at least links to her account from past posts (Genesis 8 products) to the forum don't seem to work. Hopefully she is well, but I couldn't find her elsewhere on the internet (past or present).
