I'm back :) Memory issue Suite 2101
Wow ! it's been quite awhile since I've used Daz, alot has changed. I'm running into a new problem. I recently purchased a prop Suite 2101, I set up prop, no lights, no luxus, each time I try to render scene, just the prop itself, no characters, no lights, etc...... Either program crashes, fatal error or not enough memory. I remove all items out of room, bed, dresser, lamps, walls, bathroom, doors, halls, etc..... leaving only main room, still same thing.
I also recieve message: The renderer encountered a memory error and the program has become unstable. Please close and restart Daz. Prop works fine, just can't render. I do not have any issues, with other props. Until I find a fix, prop is useless. Thanx for assistance.
What is your System Specs as in BIT and Total RAM? They both apply here.
System specs....
That item is 'heavy'...and may be crippling to some computers. Basically if you aren't running a 64 bit system with more than 4 GB of RAM, you are not going to get very far with the latest version of Studio.
Yeah, it will run, but you will be limited to small scenes and not a lot of the latest bells and whistles.
Thanx friends, OS: XP, 32bit, Dual core 3.5Ghz, 2GB ram,. I don't have that problem with any other props I use, Queen of the Nile, Mod living, Classic deco, Ultrumarine ocean, etc..... just suite 2101 prop. Alright not enough computer power.
Yes. Your very low on Mem to RENDER that beast. It is a Beast even on my i7 64bit with 64Gb Ram. Your PC just not upto the task here.
Thanx Jade, time for an upgrade. Daz is an awesome program, but rendering can discourage/disappoint easily :)
