Textures not updating.
Hello.. so I am using Toon generation character based on Genesis 8 male... I've put a 512 x 512 texture on his shirt with a logo... I go back to photoshop to resize and reposition the logo, save etc.. back in DAZ, the texture doesn't update... my only workaround is to close DAZ and re-open it! any clues?
thx!
Marc.
  • HylasHylas Posts: 5,287
    Did you give the edited texture a different name? You should do that, or DAZ gets confused.
  • NorthOf45NorthOf45 Posts: 5,824
    Try the Purge Memory utility script (in the Scripts/Utilities folder in your library). Textures are cached, so if the filename is the same, the new image is not loaded.
  • It's one of my bug bears about using daz, you can't reload the texture and it doesn't auto detect changes. My 20 year old 3D software does, not daz.
    Save it in the same directory and add something like 'b' to the end of the name, then load that into the slot instead.
