hello i wonder if anyone can help with this error ???
iv got this error from daz log but im not sure what it means or if its effecting my performance of render
WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(305): Iray [WARNING] - IRAY:RENDER ::   1.0   IRAY   rend warn : The 'iray_optix_prime' scene option is no longer supported.
if anyone cna help thanks :P
  • LeanaLeana Posts: 13,501
    It's not an error, just a warning.
    There was an Iray parameter to enable or disable Optix prime in older versions of Iray but it was removed before Daz removed the corresponding parameter in DS, so the render engine simply tells you that it will ignore that parameter.
  • ohh ok so my daz should be working fine? thanks for reply
    Yes, it should work fine despite the message.
  • thanks for your help Leana :)
