Question about "Daz Studio 4 Scene Tools Set 2"
Does anyone use this tool?
https://www.daz3d.com/daz-studio-4-scene-tools-set-2
About the sensitivity adjustment of translate and rotate sliders.
Does this tool provide a global setting (once it's active) or do I have to activate it everytime I use a different object or node?
  • HavosHavos Posts: 5,706
    It effects only the selected item when you click it, and that changes the translations and rotation sensitivity to 0.01, which makes it much easier to fine tune an items location once it is close to the correct position. When you click again, the sensitivity is swapped back to the more normal setting of 1.0 (although some items are 0.5 when loaded in).
    I use it a lot, indeed it is the part of that product I use the most.
