Genesis 8 Female's Pelvis is tilted despite Bend, Side-Side, Twist controllers all at zero.
FlortaleFlortale Posts: 611
This is so odd. I can't figure out why the pelvis would remain tilted when all the controllers are set to zero.
Image removed
The right and left thigh have been symmetrified with the exact same values except negative.
Why is the Pelvis tilted? How do I fix that? I know I can just reset the pose, but I want to figure out how to fix this problem in case it happens in the future again.
Edit: I forgot about the hip.  There's a Hip and a Pelvis.  I had to reset the Hip Bend, Side-Side, Twist controllers to zero in addition to the pelvis.
  • GordigGordig Posts: 10,803
    A quick and easy way to troubleshoot things like this is to open up PowerPose, select a node, like the hip, then hold down the alt key and click the node again. That will reset all translation for that node.
  • One is the "node" andone is the actual bone. Looks like your "node" is what is angled. The "virtual-container" for the whole model.
  • Please remember to switch to smooth shaded mode if you are taking a screen shot of a nude figure, or clothe it. Black bars are not acceptable.
    It was the hip bone. I assume by "node" yu mean the figure node, as opposed to the bone nodes - all the items in the Scene pane are nodes of one kind or another.
