Making a character cry
JOdelJOdel Posts: 6,322
I need a refresher course on this.
I've got AlFan's tears packages for both G3F and G8F, and I've used one of them on Edie 8 in the past, and it worked.
Now I need to do it again, and on Edie 8 again, and I can apply the G8 set, and I can see that they've applied, I see the eyes brimming with tears. But I can't find any morphs to make any of the tears fall. I can't find the tears in the scene list to select them and look for morphs.
I tried applying the G3 version and those don't show up in the scene list either.
Where do I find the actual tears?
    Are they on a geometry shell?
  • Mart1n71Mart1n71 Posts: 132
    The tear morphs are in the G8F eyelashes attachment.
    Show them my DAZ 3D cumulative bill? Or would that get a laugh instead?
  • JOdelJOdel Posts: 6,322
    Yeah, but they don't show up in the scene list, so I can't select them or look for the morphs.
    I can select the eylashes, but I still don't see any tear morphs. I finally gave it up as a bad attempt, and did the scene without. But I would like to know what went wrong. The scene where it worked was probably done in 4.10. Is this likely to be *another* screwup in 4.12?
  • nemesis10nemesis10 Posts: 4,011
    I'm not sure which set you have but I would select your figure, go to Shaping tab and look through the various shaping morphs of Head and Eye.  Fortunately, you can just go to top of the of the Shaping tab, select the figure in the Shaping Tab and search for tear.
    edited February 2020
    Will have to do that. I did take a look through eye morphs and didn't find anything. But I'll give it another try, once a render finishes.
    There is certainly nothing in the scene tab to indicate the product has been added.
    I'm also going to double check what my purchase dates were on both products. It's possible that I was using the G3 product back when I did the version that worked. But I suspect it may be more a case of 4.12 having screwed it up.
    Post edited by JOdel on
