parameters tab, tabs horizontal?
MistaraMistara Posts: 38,675
edited March 2014 in Daz Studio Discussion
i'm watching the parameters tutt, the tabs are on top, rather than on the side? how'd he do that?
and, was there a trick to getting rid of 'what do i do' clutter?
Post edited by Mistara on
  • frank0314frank0314 Posts: 15,111
    Different layout maybe
    but, how can i move the tabs to horizontal?
  • fixmypcmikefixmypcmike Posts: 19,723
    Window > Workspace > Orient Tabs Along Top
    653 x 285 - 75K
  • JaderailJaderail Posts: 0
    Mine has been set that way to match the old DS3A style that I still prefer.
    awesome. thank you :)
    one of my big problemos, the menu font is so tiny it swims in my eyes.
    after i make a pane undockable, how do i make it dock again?
    -thanks!
    389 x 500 - 17K
    i'm using the city limits layout. i tried to use customize to put the 'advanced menu' on the menu.
    sees it in the list, but how to add it?
    couldn't find the secret button, lol
    thanks.
    To Dock you just DRAG the window (pane) where you want it.
    not seeing that option :(
    1633 x 1005 - 198K
    ahahhhh somehow this could add the command?
    620 x 650 - 86K
    You can add it using Customize or just switch to a better layout
    got the tabs orients! yayy! thanks. :lol:
    can i save a, i guess it's a pane. so for instance, when i open the render settings tab, can i group another tab with it to open together?
    can i open 2 content library tabs? or 3?
    i'm doing a lot of scrolling up and down to get to the fancy lights
    You can't have 2 content library panes but if you use the tree view you can have it display two side by side and you can have the Lights and Cameras panes as well as the Content Library tab.
    side by side is fabulous. Thank you! :cheese:
  • macleanmaclean Posts: 2,438
    To group tabs side by side in one pane.
    Say you have Content in its own pane and you want to add another tab.
    Click on a tab (where its name is), hold the mouse and drag it alongside the Content tab in the pane.
    If the tab is in a pane with others, it's sometimes easier to drag it to the center of the workspace so it becomes a pane, then drag it to your chosen pane.
    I have 4 panes with all the tabs I need in them - 2 on the left, 2 on the right - and they're grouped side by side, with the lesser used pane on the monitor edge (far left and far right). When panes are docked side by side, you'll see a pane 'button' appear which allows you to open/close the entire pane. So I just keep the edge panes closed until I need them, leaving only the main left and right panes.
    mac
    I run a 100% custom Style, it is based on the Old DS3A layout but gives me access to every tool DA4.6.2 has to offer. I can work very fast with this layout... Warning its a 1920x1080 image...
    I only have the Pane(s) I need open when working, here they are all on screen at once...
    1920 x 1080 - 271K
