Morphs missing. Where'd they go?
I recently had to do a clean re-install of Daz. I've installed Genesis 8 Female and Male Body and Head Morphs, but the Morph Dials are nowhere to be found. Anyone have any idea how to fix this? I built a lot of custom characters with those morphs and now I can't use them at all.
  • All of them? There have been a couple of posts form people having trouble with the Genesis 8 female Body Morphs, but not the others.
    I'll double check. Maybe it is just the female body morphs. What was the solution there?
  • It was just the female body morphs. I did a manual install, then updated the metadata and I'm back in business.
  • Nope. I was wrong. I thought I had it figured it out, but they're still not there.
  • LeanaLeana Posts: 13,498
    Did you install them with Connect initially? If so, did you uninstall the Connect version when you installed them manually?
    If a Connect version is present DS will use that one by default, so if it's broken just installing with DIM or manually isn't enough, you also need to remove the Connect version.
    Not sure. I've resorted to the nuclear option again and wiped Daz off my drive and am installing from scratch. So far so good.
  • I'm no sure there was one, but ti would at least then be prt of the same issue which might help.
