Face transfer makes Character skin red
In many cases Face transfer makes Character skin reddish- why is that
I can see in the Surface tab that the Tranclucency color is red but dont
know how to make it natural..
  • gniiialgniiial Posts: 231
    There are 3 ways i use, when i try to match the skin coloring.
    The first is to adjust the color from the face texture to the skincolor of the body texture in photoshop (many image editors should do the trick). You can google about matching up skin color. You wil get a lot information about photo editing. Thats what you want to study.
    Then i have only slight changes to make. One i do with the FacemMapSSS texture, what would be the second step. So set a SSS base picture at Translucency Color.
    The last step is to adjust "maybe" a little the Translucency Weight setting. But if you have to adjust a lot there, then something is wrong with the textures you put to use.
    I would try then to take out all other textures, matchup all skin surface settings, set all the normal Base Color textures and build up from there down to the displacement everything else.
